battery drainage
Theliakos
battery drainage
Screenshot_2014-03-06-20-30-17.pngi bought my phone at 19.2.2014 since then i have used it normally ! but these last days i have this problem  !android system drains a lot of battery ! please help me and i tryed flashing it again so no use ! Screenshot_2014-03-06-20-30-26.png
30 REPLIES 30
Theliakos
anyone ?? come on guys !!!
profile.country.RO.title
_alexdon_
You definetely have apps acting up in the background.Boot your phone in safe mode and see if the same occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
prometej-zg
First of all, your screenshot aren't (yet!) visible. So it is hard to tell what can be the problem.
I had similar problems with android stayed awake and draining the battery, but in this couple of times it was only needed to restart my phone and nothing else.
I your case, maybe is some application that keeping awake your phone?
Maybe antivirus or some kind of app that is always active, (e.g. Facebook app, Email, etc.)
Last problem I've noticed is mediaserver and Walkman app as cause of my problem with battery drain.
You said you have flashed your phone? It takes some time for Android to settle down after update. So if you upgraded your phone when you bought it and now reinstalled it, then it may still be settling down.
On the other hand did you make discharge (under 20%) and charge of your battery after update?
There are many possible reasons, but some of  them are more likely to be, then others.
EDIT: Well meanwhile pictures and another suggestion came on 🙂
Theliakos
ok say that i booted ! how am i going to find out which apps are they ?
Theliakos
wait way they are not visible ?? and man no ! i flashed my phone time ago about 6 days andd i discharged the phone
_alexdon_
Use your phone for about 1 day like that and see if the same drainage occurs.If it is fine,you have apps acting up(task killers,battery savers,phone optimizers).
alexdon
Theliakos
ok so the problem now is clear ! tha fact is i dont use any task killer or anything else just system apps !
_alexdon_
So you have manually flashed your phone?
alexdon
Theliakos
well i repaired with seus !
