Hello all.
Is it fair to say that my new z4 tablet will take a few cycles for the battery to hold its charge.? I know my Samsung devices do, and im sure most other products. Just wondering if this was the same.
Thanks you
Colin..
It'll be wise to reinstall the latest update with PCC, it will smooth things out and improve battery life
Bridge (for Mac)
I wouldnt have a clue how to do this. Can you help with that maybe?
Again its only two days old, will the charge cycles not help. Also i have the keyboard attached all the time, connected via bluetooth I believe. This wont help with the drain will it?
Thanks
Colin..
it's quite simple install PC Companion on your computer or Bridge on your mac > support Zone > repair
settings > power management > battery > check the graph and the list, what has been using the battery?
Thanks for that. Will give it a go...
keep us updated
Hi @Sony5100!
If you still notice a drain a few days after the software repair then have a look at the tablet's battery usage, Settings > Power management > Battery usage, when the battery is down to around 25% or less to see what has been using most of the battery.
