Xperia Sp Stamina Mode Crash / Not Working.
ak_newlife
Stamina mode is not working for me
-- Initially it worked but after few days it shows me the same time with stamina mode on or of.
-- i have flashed the phone and also tried the factory restore... but the problem resurfaces again after few hours or days.
-- also iam not sure but this error has turned up after the firmware update.
29 REPLIES 29
have you disable any app?
do you have any
taskillers
task managers
antivirus
battery apps
ram apps?
ak_newlife
This started happening after 3 days of basic use of the phone
Have installed office pro, few games and 1 gb of music files apart for basic sucial apps like whats app facebook twitter and mails wifi analyzer
the problem had repeated even before i restored my phone when i had just flashed via Pc companion
but do you have any of the apps I'd listed?
ak_newlife
No non of those have been installed
nor have disabled any apps nor have i tried to force stop it nor have i tried to ristrict any functionality.
ak_newlife
Hi
MA attaching the images have a look and let me know
oh ok, now I understand your issue
tap on STAMINA mode > if you have excluded (add apps to the list) apps that require data/wifi connection then your data and/or wifi will be on, thus defeating the purpose of having STAMINA mode on
ak_newlife
thats the point i have not added any apps to the list all the setting for power management are at default.
and also if a do so there should be some difference in the timing of the stamina mode being on or off.
and also as i have said before the same setting used to show a difference of any where from 1 day to 2 days and from 10 hrs to 30 hrs
when the stamina modw is switched on or off
that's odd, but then again, since you just got your phone its normal that it will behave like this
this should clear some questions
http://talk.sonymobile.com/thread/127317
