Battery Charging
TINA66
Battery Charging
Why does it take so long to charge the battery for my Xperia Z3? Once it's fully charged i'm quite satisfied with the amount of battery usage . I used to have the Z1 compact which I found had an excellent battery - quick to charge as well as a long life!
Anybody else having the same issue?
28 REPLIES 28
martinmrmus
but i need it turned on...
dandy63
Leader
What i was meaning was try it switched off just to make sure it goes all the way up to 100%........possible reason its only going to 99% whilst you have it switched on is due to apps etc running in the background etc
@stockyvillage that's quite odd, perhaps @Rickard could comment on this a bit further.
stockyvillage
@ uliwooly I am going to run the phone down to 20% and put it in dock and time it.I will post time on here. Will take a while to get to 20% though,as I am on 86% at the moment
It'll be wise to repeat the process one with a quick charger and another time with a regular charger, if possible turn off the phone while charging.
stockyvillage
@ uliwooly will do it from 70%/ one with DK48 and then with standard Sony charger and phone off both times
sounds good, keep us updated
stockyvillage
First charge using Sony supplied wall plug charger with phone turned off. From 70% it took 1 he 29 mins to reach 100%.Will post DK48 results later
stockyvillage
2nd charge using a belkin 2.1 amp plugged into the DK48.Phone turned off again,took 1 hr 1 min from 70%..Next charge will be DK48 using Sony.supplied wallcharger
keep testing, thanks for the feedback
