Sound fading in and out on call
Wej
This happens even when I have full signal, the sound fades in and out between normal volume and inaudible at second intervals.
Not sure what to even try with this.
3 REPLIES 3
Hampus
That sounds strange. Does this occur everytime you place/receive a call? Have you tried to place some calls while using a headset to see if same thing happens?
Wej
No, I've not tried a headset, but sound doesn't fade in and out when listening to music etc through the phone speakers so I don't think it's a speaker problem. I thought it must be signal/carrier related, but the signal strength doesn't seem to make any difference.
Hampus
In that case, I suggest that you try another SIM-card. Perhaps a SIM-card from another network provider to exclude problems related to your carrier's network Otherwise, you may want to perform a software repair via PC Companion:
http://support.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
