i have tried it with 15 different applications and 6 different bluetooth headset, this is the most bizzare problem of Z3 compact.
Auto-answering doesn't work while using bluetooth headset. i have tried it even with the original Sony bluetooth headset, there is no solution.
now i have to push answering button on my headset for incoming calls. im a dentist and this problem is my nightmare.
please help me. thanks.
I understand the frustration, could you list the apps that you have tried, also, have you contacted the app developers?
i've tried this apps;
handsFree Answer, plantronics hub, Hands Free, Ultimate Car Dock, New Car Mode, Bluetooth on call, Call to Bluetooth etc. etc.
my headsets are; sony mbh10, plantronics ml10, nokia bh-105, motorola h300
i have also tried; Sony MBH20 and motorola s9
if you are dentist or if you have to use your two hands while working, you will be upset, because theres no way for auto-answering in bluetooth mode. if you are using bluetooth headset, you have to push button for answering. it ruins your life.
I'll escalate this and let you know but I think that's how it supposed to work with bluetooth.
I'm not sure if it will work as this will depend on the 3:rd party apps used but perhaps you could try an app that tries to force the audio route to the headset like SoundAbout.
If that doesn't help i recommend that you contact the developer of the auto answering app to see if this is possible.
i have same problem. bluetooth auto answering function is standard in other android phones, but i cant see it on Z3 Compact. i have also samsung galaxy phone. this is screenshot from this phone;
@hakozen @h7kn are you the same user?
Either or, @hakozen your issue its different, if you check on that screenshot that you've provided
Automatic answering
Automatic answering only operates with a connected headset, not a bluetooth.
Also, those are not standard Android settings, since they can't be found on a Nexus device
i used many phones. all of them had auto-answering function in their bluetooth modes. im waiting for android 6.0 update. if it would not be fixed, i will never use any sony product again.
Did you read what I've posted?
which devices have this option? and if possible post screenshots of that menu, thank you.
