Audio problem using headphones
sgtpepperpco
Hello,
I have a Xperia Mini Pro SK17i and I have a problem in recent months.
When I use my smartphone without headphones connected via the jack,
The sound is perfect, all the speakers work well, I can listen to music and hear the phone ringing notifications ...
However, when I plug headphones into the jack on the headphones is jerky at the rate of a clock, I hear the staccato sound! If I listen to music, the sound is choppy, if I unplug the jack, the sound of the speaker's normal ... Out I did not have this problem before ...
I also noticed that when data is transmitted, the problem stops temporarily when I send a message, the problem stops the time the message was sent ... Same at the reception ... When I connect to the web via 3G, same thing, so when there is data transfer over the network, the problem stops while data transfer!
I tried to move the Jacks made, I bought a new pair of headphones Sony Xperia, but persisste problem!
Thank you for your help.
Sincerely,
Y.Molle
4 REPLIES 4
This is an English only forum
@sgtpepperpco wrote:
Bonjour,
Hello,
Sincerely,
Y.Molle
Don't forget to give Kudos
What if you try with different headphones?
sgtpepperpco
If i try with different headphones it's the same thing, i also tried to test on a Hi-Fi amp but no amelioration... I think it's a problem on the PCB... Probably a bad compents but what can I do...
You have to take your phone to a Sony repair center
