How do I check which version I have on my Xperia 8, & what advantages are there to me if I update it?
Also, I have a 2gb memory stick. Will it take a higher capacity stick?
Thank you.
Tap on settings,scroll down and tap on about phone,scroll down and u should see firmware version,that is ur current software version of ur x8.
Xperia X8 TOP 5 Benefits of the upgrade:
*improved Bluetooth functionality with support for sending and receiving objects.
*.New Backup and restore application with extended contentbackup.
*.Social phonebook, which automatically syncs contact pictures from Facebook.
*.Improved ways of handling pictures, audio, text and numbersin your messages.
*.Upgrade of the Android platform to Android platform 2.1.
Yes u can expand ur sdcard memory upto 16gb.
Right, thanks, I found it. My version is already 2.1-update 1, kernel version is 2.6.29 so I expect it's pretty much up to date. As my 2gb card is almost full, is it like a pc which slows down when the hard drive is almost full? If I insert a larger caopacity card but still only use 2gb will it work any faster? I especially find some books in Aldiko reader are a bit slow. Reading a book is fine, but I have a large refernce book on & it takes a while to locate the right page.
Thanks for your help
