WEP Wi-Fi issue
WEP Wi-Fi issue
Hey guys I have a big problem: I am at my friend, he has a router secured with WEP, I connected to it but it says Limited Connectivity and I can't access the internet. I happened everytime whenI connect to a WEP router. The problem is, that only his dad knows the admin password for router settings, so we can't change the security to WPA or Open. I have no wi-fi at home. Please help me make WEP Wi-Fi work!
28 REPLIES 28
I have WEP wifi at work and it worked just fine, make sure you have the correct password
you can try this
https://market.android.com/details?id=org.marcus905.wifi.ace&feature=search_result
or look for other similar apps on the market
Ok thanks I will try that and... by the way, how can I install apps from android market via USB? I have no internet connection on my Arc but I logged in to gmail at a time so I have it in list on android market.
About the password: I'm using the same password that he uses on his LG GT505 and it's working on his phone.
you will have to download the Apps (APK) to your computer from
either
http://www.freewarelovers.com/android
or
http://www.freeandroidware.com/
or
http://www.androiddownloadz.com/
then mount your phone to your computer, I suggest ou put all the apps in one folder and call it APK, then transfer it to your SD card
Thanks I just needed a source of .apk files Slightly_smiling_Face I'm trying now
Ok so what should I configure?
but this File Manager app must be install from the market before you can install other apps
go to Settings -> applications -> make sure Unknown sources is selected
once you do that, open OI File Manager, go to your SD card -> APK -> tap on one of the apps and tap on install, repeat the process with the rest
Ummm... it's not the first time I install apps Slightly_smiling_Face Just tell me now what do I have to configure in this app?
let me know if you need more help
I would just try the password again w/o this app, and if it doesnt look for the network and enter the WEP key at the bottom
