Viruses that are infecting Windows might not create problems on Linux. Usually,there aren't viruses on Android,maybe some spyware.
I don't think that this virus affects Android systems, there's a possibility though that it might infect your memory card if you connect your phone in MSC mode. So the only suggestion is to remove your memory card and fix it into a card reader, and scan it on a clean PC.
To check your phone use Avast from the Play store also Viruses do exist for Android but a Pc wouldn't detect them due to the coding strings used
screnshot here is screnshot when i want to scan phone i know phon memory aand sd cart but what are other two memories
Not sure why the apps finds 4 memories. There should be phone memory,internal and SD. But scan all of them if you can.
