I do not own this post or whatever, just sharing.
Guys, can anyone try this rooting method and report back? I was not
able to bring my USB cable at work so I am not able to try it now.
STEPS
SOURCE
[P/Go][ROOT] DooMLoRD Easy Rooting Toolkit (v14) {perf_event exploit}[20130624]
XDA Thread Link http://forum.xda-developers.com/showthread.php?t=2335992
Thanks to DooMLoRD from for the method
Thanks to eswawan for sharing it first in the Xperia Go Android Development XDA page.
Hope this helps and hope it works. :smileygrin: :smileygrin:
MODIFICATIONS AFTER ROOTING
I added this because I want to share what I and you have done with the Doomed XGo
phone after rooting. Please let me know what you have done too so that we can add
them to the list below. THanks
1. Modified the Phonebook, Phone and the Messaging app with DARK Themes
click here originally by jatinrungta from XDA
2. Debloated [JB Update] [6.2.A.1.100] List Of Apps/Bloatwares That Are Safe to Delete. Thanks to taboo5200 for the safe list :smileygrin:
3. Installed Root version of greenify to save battery and RAM. Check here
I will add more if you tell me so. :smileygrin: :smileygrin: Thanks
i think that's normal but there's a difference. If you noticed, those with line below the images are those contacts/sender which you are allowed to response or reply but take a look those sender/contact like service numbers or machine generated text sent to you, no lines below the images.(e.g BUDDY, 211, 8888,SMART,GLOBE,etc)
Woooh!! Cool! Thanks you for noticing bro.. I guess
I do not have to worry anymore.. Thanks thanks
I updated the original post for some of the modifications that I made
with my phone related to rooting.
If you have modifications of your own from the stock JB 1.100 ROM and
doomed rooted, please share them here and I will update the original post
with your modifications. Just add the modification, the steps that you did
in order to achieve your modification, and, optionally, add the source link :smileygrin:
Thanks,
Eljun
Ok Guys, I rooted and installed CWM. So far so good... Now i see different posts and opinions, about what modifications make, and what mods/fixes install ?? Any suggestions, does anyone have a nice list of recommended and nice JB go mods for the latest version??
PS1:
should i manually debloat, or use this:http://forum.xda-developers.com/showthread.php?t=2137123
PS2: http://forum.xda-developers.com/forumdisplay.php?f=1519
On the above link i see a lot fo mods for xperia p, usually, mods for p also are fine for go right?? (even it doesnt state that is for go)
Thanks!
Umm... complete noob here
Tried this... but I press any key to continue, it just gets stuck at 'Waiting for Device'
What am I doing wrong?
Have you enabled USB debugging?
Hope someone could port/install Xperia ZU's theme to Xperia Go. It's pretty clean and nice. It's already working on sola, U, and other Xperia units.
So guys! After almost 3 weeks what has Root brought to all of you? Why so silent? What mods? Root apps have you installed? Speak your minds!! ;D I've basically setup the cpu to min:400 max: 1000 and have other root apps but no biggy! And very very satisfied! ;D
Me I'm using ondemand governor 800max 200 min and enjoying great battery life I've also made some MODS like debloat and few scripts and build.props MOD, if you want it checkout my link http://forum.xda-developers.com/showthread.php?t=2348778
Im checking out your work kinglauryl. I've been looking at the xda apps and mods forum... there is so much stuff, that i didnt know how to begin and what was worth installing, i guess you did that for us.. Also some people flash the new bravia engine and some cybershot camera mods, are that worth? would be nice to improve even more our camera..
What do you think of that ?
