I do not own this post or whatever, just sharing.
Guys, can anyone try this rooting method and report back? I was not
able to bring my USB cable at work so I am not able to try it now.
STEPS
SOURCE
[P/Go][ROOT] DooMLoRD Easy Rooting Toolkit (v14) {perf_event exploit}[20130624]
XDA Thread Link http://forum.xda-developers.com/showthread.php?t=2335992
Thanks to DooMLoRD from for the method
Thanks to eswawan for sharing it first in the Xperia Go Android Development XDA page.
Hope this helps and hope it works. :smileygrin: :smileygrin:
MODIFICATIONS AFTER ROOTING
I added this because I want to share what I and you have done with the Doomed XGo
phone after rooting. Please let me know what you have done too so that we can add
them to the list below. THanks
1. Modified the Phonebook, Phone and the Messaging app with DARK Themes
click here originally by jatinrungta from XDA
2. Debloated [JB Update] [6.2.A.1.100] List Of Apps/Bloatwares That Are Safe to Delete. Thanks to taboo5200 for the safe list :smileygrin:
3. Installed Root version of greenify to save battery and RAM. Check here
I will add more if you tell me so. :smileygrin: :smileygrin: Thanks
Thanks for the heads up but i dont have 6.2.A.1.100 yet and this couldn't root my phone so i am still wating
how much time will it take to finish the rooting and what will it display.............. wen finished in command screen.........
Time? 5min ?
It says something like "COMPLETE!" and the phone reboots! 😐
Guys! Stop trying root apps! LOL!! Geebus! Fiddlin' with System Tuner ;D
@mad_go YO! I use No Frills, is set cpu bettah? :smileygrin:
Never tried frills, I uninstalled set cpu though, System Tuner does it all! ;D
Now that it's rooted, can I change the kernel even with locked bl? 😐
Nevemind, dumb question!!
Fiddling with System Tuner is the shiznit! Much faster, battery performance must decrease of course but, screen off goes to 200mhz so... I'm very happy! It even hasa Build option where you can change values like, Power Saver, Improve Responsiveness, Improve Call Ringer Speed, Improve screen on speed during calls! More! Much MORE! ;D And FINALLY!
1GHz x2 Foh evaaaah! ;D
Short answer: No.
Long answer: No, because the kernel resides in the boot partition, which must be signed by the manufacturer (i.e. Sony) before the bootloader will boot from it. Unlocked bootloaders will bypass this restriction.
Thanks once again Taboo! ;D
Still happy though! ;D
I get:
CONFIRM ALL THE ABOVE THEN
Press any key to continue . . .
--- STARTING ----
--- WAITING FOR DEVICE
The system cannot find the path specified.
--- creating temporary directory
--- cleaning
no root. I have a locked BL.
EDIT: OK, so you need to run in MTP, not MSC mode.
I had that too! I then, desperately, tried to force my way into ADB mode by:
Pressing the Vol. + Button and then inserting the USB cable ;D
Give it a try and give some feedback! ;D
OH! Is USB debugging mode ON? In the dev options?
yes, debugging is on. I am root already, so won't try other tricks. MTP mode helped me.
