How do you do? Can you help me? I have any incorrect style of texts on me phone. On other phones there are some styles with colour, some with bold font etc. I don't have this in the same apps and cases. Just look on the numbers and info about my battery remaining.
Thank you for quick responce. I've found a problem. In menu "Accessibility" was turn on "High-contrast text".
Are you using a custom launcher or theme? Try to disable them and revert to a pre-installed theme along with Xperia Home launcher and see if it's fixed.
Great that you figured it out, and thanks for sharing the solution with us.
