Bonjour,
Depuis la mise à jour du système Xperia, snapchat ne fonctionne plus correctement.
Lorsqu'on active les filtres, quand l'appareil photo est ouvert, ça beug...
Si quelqu'un a une solution ...
Hello,
Since updating the Xperia system, Snapchat no longer works properly.
When you activate the filters, when the camera is open, that's okay ...
If anyone has a solution ...
GT
The problem only appears with Sony. On Samsung iphone and no problem. I do not see how the problem comes from snap! And it's since the last update Sony.
Apps developers should do their apps compatible with the different phone brands, and not the other way around. So, please, get in touch with Snapchat developers.
I have the same problem, and it's an internal problem with Xperia XA1, I still have my old Xperia M4Aqua, I installed it Snapchat and it works properly, everything's fine.
There should be something Sony can do.
Same problem with the xa1 effects are bugged out
Same problem 😞 i hope Snapchat Bring a Update
Same here! I've had my XA1 since April 2 and before that I had an M4 Aqua. No problem with the M4
Yep facing same problem
