Bonjour,
Depuis la mise à jour du système Xperia, snapchat ne fonctionne plus correctement.
Lorsqu'on active les filtres, quand l'appareil photo est ouvert, ça beug...
Si quelqu'un a une solution ...
Hello,
Since updating the Xperia system, Snapchat no longer works properly.
When you activate the filters, when the camera is open, that's okay ...
If anyone has a solution ...
GT
J'ai le même problème!!!!
I have the same problem
GT
Tengo el mismo problema, necesito una solución o deberé sacar la actualización del sistema?
I have the same problem, do I need a solution or should I get the system update?
GT
I'm having the same problem! Along with quite a few others since the update!
This is happening to me. Any advice would be helpful thanks
I’ve installed it, just to try. Same problem. Maybe you should contact Snapchat support...
sadly I am also experiencing the same issue.
@MikaSancho @elcane @Jetzu @Maia2000 @Jo775
Snapchat it's a third party app, you have to report the bug with the app developers, as it's up to them to address any bugs/compatibility issues.
https://play.google.com/store/apps/details?id=com.snapchat.android&hl=en_US
Had the same problem and reported it to snapchat but still no reply :(. Also had a few other issues since updating tbh.
I have an issue with my front and back camera on the Xa1 ever since the update.
Snapchat camera and filters are bugging out. I've Uninstalled and reinstalled the app, cleared cache numerous times but still not working.
Does anyone have any solutions to provide please?
