Ringtones and alerts turn off randomly
Markef
Hello
This is my second Xperia XA2 Ultra.
I returned the first one after three weeks for the reason described below:
In a way that I designate as random because I have not identified any trigger event, the sound alerts and the buzzer are disabled. I think I hear them very weakly. The volume is at maximum. The phones have been restored from the factory. The update is 50.1.A.10.40.
A simple reboot is enough to restart everything.
Does anyone know the problem?
I thank you in advance.
cordially
Marc
Sonneries et alertes se désactivent de façon aléatoire
Bonjour
C'est mon second Xperia XA2 Ultra.
J'ai renvoyé le premier au bout de trois semaines pour la raison décrite ci-dessous :
De façon que je désigne comme aléatoire car je n'ai pas identifié d'évènement déclencher, les alertes sonores et la sonnerie se désactivent. Je pense les entendre très faiblement. Le volume est au maximum. Les téléphones ont été restaurés d'usine. La mise à jour est 50.1.A.10.40.
UN simple reboot suffit à tout faire repartir.
Quelqu'un connait-il le problème ?
Je vous remercie par avance.
Cordialement
Marc
3 REPLIES 3
@Markef
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Does this happen all the time or only after your phone has been on "Do not disturb mode" ?
Markef
Hi  Uliwooly
Thanks a lot from translate me.
I never use the "Do not disturb mode".
This happen sudenly. When the phone is in sleep mode or when i use Waze.
At less one time each days.
Regards
Marc
Markef
Hello
The cause of the problem comes from its connection to Car Cigarette Lighter Socket USB Charger Power Adapter.
I tested several on several cars, the result is the same: I have no ring after.
I do not have this problem with my other smartphones.
I had this problem with two XA2 Ultra. I deduce a problem with the XA2 Ultra.
I return it for exchange against a model of another brand.
Sorry
Regards
Marc
