cannot connect to any wifi because my phone cannot see available connections even if there are available ones
You have WiFi switched on?
First try in safe mode.
It will disable all self installed apps and you will have a rather clean machine.
Sometimes an app is causing trouble.
If the problem isn't find then you can follow the steps as described in support.sonymobile.com.
You can also follow the steps as described in the FAQ.
