hi all,
I have X Performance, SOV33 upgraded to Oreo 8.0, I want to extend limit of SMS characters, how i can do this?
regards
SMS limit is controlled by the operator and it's limited to 918 characters. However, if you type more than 160 characters, your SMS will be divided into chunks with 153 characters in each. Using non-Unicode characters (like Arabic, Russian, Chinese, etc) will reduce this limit to 70 characters per SMS.
thanks @Quester for reply and guidance.
I can't type after approx 150 characters - using all plain text alpha-numerics only, it is not accepting. Is there any other SMS app advised to use instead of stock?
have installed Textra, searched for best sms app and then selected this one.
thanks for help
at the moment i am at work, can't use it, will definitely give you feedback. i am using their provided internet connection, at home i will install the selected Textra SMS and will check.
regards
hi,
I am happy you help me to solve the problem
sent message of lenght approx. 500 characters and Textra sent it without chunk means at once.
once again thanks very much.
regards
