Heating automatically
JB08
It had 82% charge at night around 12.36 am. It got heated so much and got switched off automatically in the morning around 7.25 am when not in use.
nathanhorner
As schetz says - something had a hissy fit and refused to quit. Did you look in your battery stats? Has it stopped?
5 REPLIES 5
schetz
Will something did get stuck.  Have you tried to reset it when you noticed excessive heat?
That's why it drained empty too. It's it happening again now you've turned on the phone again?
nathanhorner
JB08
yeah I checked everything was quite normal. Now I gave it to the Sony centre. let's see what happens. Thank you buddy
12gh
My mobile heating issues every day pls solved this promlem
profile.country.NL.title
Strampke
@12gh
You're not alone.
Others had good results with Xperia companion.
Make a backup and then do a software repair.
After repair don't put everything back; just the apps you really and urgently need.
Man and machine
Keep yourself clean
Or be as has been
