Clock unlock screen
Giulia17
Clock unlock screen
C'è un modo per impedire che l'orologio della schermata di sblocco cambi semplicemente tenendolo premuto? Molte volte tirando fuori il telefono dalla tasca trovo il che l'orologio è cambiato da solo e è una cosa piuttosto fastidiosa
Is there a way to prevent the unlock screen clock from changing simply by holding it down? Many times taking the phone out of my pocket I find the clock has changed by itself and it is quite annoying
GT
13 REPLIES 13
GingerSteve77
This is the same screen I see as well, So the only time I get issues is when I also have a clock widget active, so I don't use widgets, just the actual system clock screen the same as you uploaded here
Giulia17
Ok lets make it Simple how can I remove my clock System from lockscreen?
GingerSteve77
It's not the lockscreen clock that gets removed, as I said I only experience some glitches when the clock widget is active , which is only viewable when the phone is unlocked I think
GingerSteve77
It's only the widgets that make my phone act up, that and stupid Google apps
