Phone idle seems to be using a lot of power and battery draining really fast any suggestions, restarted phone no joy cheers
I have the same problem. After last update, the phone started to heat. And battery is being consumed very quickly. I am using same apps before the update. Before the update I did not have these problems.
I advice you to factory reset Your Phone, or, if this is not sufficient repair your software with companion by your PC, it resolve any problem.....my Device fly after this.
As @Mino88 suggested, if you are having no luck with the rest of it try a software repair using Xperia Companion.
Ended up doing a factory reset as I couldn't get the software repair to work kept failing now it won't charge past 95% driving me mad
If you are unable to do the software repair using Xperia Companion, then I recommend you contact your Local support team to arrange a repair assessment.
Hi Sony,
I am running the latest update of android oreo version. It seems after update my phone drains out quickly. I have the Sony Xperia X model.
Hope you guys can check out and fix it!
Cheers,
Ahrkitek
