After N update, problems with network coverage
Othman22
So many time network dead..
Also apps stopped working
Emir1
Hero
Hi @Osman2222, I'm sorry to hear that. Slightly_frowning_Face
Which network are you referring to, is it the mobile network towards your operator? What happens when it dies, do you lose coverage and then it comes back, or what are you experiencing in a bit more detail? Is it restricted to mobile data, or does the whole network coverage drop so that you can't receive/make calls either?
Regarding apps, which apps stop for you - is it third party apps or native ones as well? Is the error message you receive that the app has unfortunately stopped, or is there some other message?
First I would recommend for you to see if you experience the same whilst having your device in safe mode, and then let me know some more information regarding what you're experiencing. Fill me in and I'll do my best to assist you! Slightly_smiling_Face
13 REPLIES 13
Lord_viridis
I'd repair in Xperia companion tbh
Emir1
Hero
Othman22
Screenshot_20170103-142750.pngScreenshot_20170107-214425.pngScreenshot_20170107-214432.pngScreenshot_20170111-173913.png
Othman22
after I select sim card for call .. I discover automatically it shifted when I make new call after little time may be 7 to 8 hour
Emir1
Hero
Thank you for clarifying what you meant, that helps me a lot!
Did you have the chance to try to see if it occurs in safe mode as I suggested in my previous post? If so, I'm afraid that I agree with @Viridis in that it would be best to perform a software repair using Xperia Companion.
Could you try that and let me know how it went? Slightly_smiling_Face
JosS1094
Hello there I have a Xperia X and I have indeed the same problem I have no network coverage and I can't make & receive calls. I'm so worried!! I tried in the Safe Mode and didn't work and also I tried with Xperia Companion and was stopped by an Error Code: UEUpdateFailed UE_2005
All this happened after I upgraded to Android 7.0 before it wasn't any problem...
Othman22
after I REPAIR PHONE BY SONY COMPANION phone is suddenly change call sim without I now
and some time no network COVERAGE also
and apps look facebook messenger is STOP WORKING
very bad after update .. also before is better 6.1 and I didn't face this problems
CAN I GO BACK FOR ANDROID 6.1
Emir1
Hero
So sorry to hear that, but do I understand you correctly in that the initial behaviour now has returned to normal? @Osman2222 Also, I'm afraid that rolling back to a previous Android version is not possible. Slightly_frowning_Face
Have you both tried to see if the same occurs while using different SIMs? If it persists even after a software repair and a fresh install (try without installing any new apps or services), and while using multiple SIMs, then I recommend that you have your device sent to an authorized service center so that a technician may have a look at it for you.
The easiest way to have it sent in would be to get in touch with your Local support so that they may assist you, as they are well informed regarding the local service routines for your specific market! Slightly_smiling_Face
tanerr
Network Problem
