My volume control close to touch pad does not work anymore. Maybe I have installed a software guilty of this malfunction but I have to find a solution without Recoverying it.
Unfortunately there is no Hot Key Patch on Vaio-Link.
HELP!!!!!!!!!
Reinstall the hot key utility.
Hey,
i've got exactly the same problem. I deleted my hotkey and can't find a way to re-install it again. Does anyone know how to install the hotkey software without needing to recover the system?
It's on the last volume of the recovery disk set.
thanks kilo!!
I have a PCG-GRT916V and received with it only one recovery disk. It also came with a disk called picture package and sonic stage.
It seems the recovery disk i have enables me to install every single software except from the hotkeys. What shall I do?:smileycry: I don't wanna recover the system as i've a lot of stuff.:smileycry:
So it's a DVD then?
There's no utilities folder on there?
i've just checked the capacity of disk and it's ideed a DVD. It doesn't have a folder called utilities. it has a folder called sony , support, I386, documentation, and valueadd.
I don't believe one has to recover the entire system just because of the hotkeys software...Strange, isn't it?
The Sony one usually has everything you need for Sony utils and drivers. The rest are Microsoft related.
I've just tried the option 'install all' and still hasn't activated my hotkeys. In the folder sony there are only two .EXE files, being one recovery and the other the main software. I suppose Sony forgot to provide in the CD the option to uninstall and install the hotkeys.
Do you know if there is any way i can download hotkeys from sony?
Thanks for your help
