GRT996ZP Volume control
profile.country.IT.title
frcalab77
New
:cry: My volume control close to touch pad does not work anymore. Maybe I have installed a software guilty of this malfunction but I have to find a solution without Recoverying it.
Unfortunately there is no Hot Key Patch on Vaio-Link.
HELP!!!!!!!!!
10 REPLIES 10
profile.country.en_GB.title
kee-lo_
Member
Reinstall the hot key utility.
levieira
Hey,
i've got exactly the same problem. I deleted my hotkey and can't find a way to re-install it again. Does anyone know how to install the hotkey software without needing to recover the system?
kee-lo_
Member
It's on the last volume of the recovery disk set.
levieira
thanks kilo!!
I have a PCG-GRT916V and received with it only one recovery disk. It also came with a disk called picture package and sonic stage.
It seems the recovery disk i have enables me to install every single software except from the hotkeys. What shall I do?:smileycry: I don't wanna recover the system as i've a lot of stuff.:smileycry:
kee-lo_
Member
So it's a DVD then?
There's no utilities folder on there?
levieira
i've just checked the capacity of disk and it's ideed a DVD. It doesn't have a folder called utilities. it has a folder called sony , support, I386, documentation, and valueadd.
I don't believe one has to recover the entire system just because of the hotkeys software...Strange, isn't it?
kee-lo_
Member
The Sony one usually has everything you need for Sony utils and drivers. The rest are Microsoft related.
levieira
I've just tried the option 'install all' and still hasn't activated my hotkeys. In the folder sony there are only two .EXE files, being one recovery and the other the main software. I suppose Sony forgot to provide in the CD the option to uninstall and install the hotkeys.
Do you know if there is any way i can download hotkeys from sony?
Thanks for your help
kee-lo_
Member
Normally everything you need is on VAIO-Link
