I have my really good phone xperia p but im facing battry problem it begins that today i charged my phone and after 2 minutes of stand buy battery went down by 2 % and it continued like this so if I want to browse in 5 minutes 10 % of battry is gone and this is not normal because i used to have a really longer life for example evry about 5 hours of stand buy 1 % is done and when browsing every 5 minutes 1% is gone so plz help me:smileysad:
Here's how I manage to keep the battery ticking[Note: I'm not saying THIS WILL WORK or this is ultimately correct]
1. Brightness. I always keep it minimal, whenever I'm indoors @home, college etc. If I need to increase it, I will, but majority of the time, I keep it low/very low, checking the "adapt to lighting conditions" - OFF.
2. Turning off Wi-Fi & Bluetooth, whenever you don't need them. Saves up a lot.
3. Turn off data too, if not required at all.
4. Keep a task-killer app, like say Astro, and often check for unwanted services running.
5. Refrain from using a live-wallpaper. [personal choice, I do use a live wallpaper, but I'm just recommending so that you can save some juice]
6. Don't use any battery-optimising/saving apps. They're all waste.
7. A screenshot for "Battery Usage" would be good here.
you do not need a taskiller, antivirus, ram and battery apps, they will use RAM and drain a lot of your battery among other issues. so uninstall them.
I agree that you should charge your battery 100% > use it as you normally do once your battery reach 10% > settings > battery > take a screenshot of the whole list and the graph, tap on each item on the list and copy all the info (post it here)
I've downloaded anti-virus just for scanning and the problem was simple 1 virus so I neutralized it and uninstalled the anti-virus and the phone is awesome right now. BTW I've read your post and actually it had 1 question that I'm googling it scince 1 week which is :is my Xperia P getting JB and when so plz tell me I you know the answer.
which virus? there aren't virus on android just malware apps.
So far Sony has said that for sure the Xperia Arc Series will get the updates (Xperia Arc Series = Xperia T, TX, V, J) no word on other Xperias.
