upgrade to 4.0 runs slower
after an upgrade of os to 4.0 from old os of 2.3.4 my neo v runs slower and crashes on games which before never did happend using the old software, any tips or suggestion for this? tnx
Nabeel
Hi, Few HD games and other games are not compatible with ICS... thats the reason they crash
However you must give software repair a try
It will erase all data on phone, backup necessary
[[[suggestion..... format your sd card before installing ICS ( for clear installation)]]]
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructionshttp://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
2 REPLIES 2
It runs slower because ICS is more hardware demanding than gingerbread. You can increase the speed by removing all the apps from sony.... it works... but the mobile is still not that fast. Or else you can always go back to gingerbread. If you think the phone app is slow go for dialerone . it increases the contact search speed and log display. the stock dialer is a sh*t...:)
Nabeel
                  or
