I have recenlty upgraded my neo to ICS. Since then, when I get a call, (even missed call) it turns my phone to vibrator mode automatically. So whenever I get calls, I have to turn on the ring manually. Otherwise I would miss the later calls. Please help.
It will erase all data on phone, backup necessary
[[[suggestion..... format your sd card before installing ICS ( for clear installation)]]]
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
or
