After use of Sony xperia Sola, i founded that Ram is too low,
I m decided to go with Sony Xperia P,
Actually, my phone budget cannot increase upto Rs.25,000/- Only(in indian Rupees) my phone requirements is
Dualcore cpu,
1gb Ram,
Atleast 4" display
good Gpu...
If Sony xperia P is not Good Option Then Please suggest me good Phone Please PLEASE PLEASE,
Thanx in Advance,
Good suggestion will mark as Correct Answer...
This is not a screen problem , but a feature of the screen.
Like sola was designed for floating touch.
P is designed for maximum readability in bright sunlight !
when you will open the P in the sunlight only then you would realise the importance of this technology ,
i would suggest you to see a working demo at the shop to satisfy your concern.
All the SONY handsets have some or the other problem's , you cant deny this fact !!
If you are ready to comrpmise on this fact as you already was a SONY customer, you can go ahead.
Morover some % of handsets have manufacturing default , it depends if you are lucky enough to get a ERROR free hardware
You have to make the decision to go for SONY or not !!
Hi Mandeep, As per the above requirement posted by u , P is the best suited one for u.. I Suggest u to go with P, and also Now ICS has been released for P. Coming to ram Even after ICS update 500 MB ram will be free
The things u should know is there is Still crankling sound coming out from speakers when Xloud is Activated, and There will be some colur shifting in sunlight Due to White magic teachnology( Which is not a big issue and u will enjy that) We guys are waiting for the Fix.
And My Suggestion is u can go for P...Good luck Mandeep
i think colour shifting is big issue bcuz screen is 2nd main thing which make good feeling,
Is this issue also in GB if yes then why it is not fix in ics,
I think it is a hardware issue...
I cant say it is Hardware Issue Because,The model Xperia P was bulid like that, Due to the White magic teachnology only u can see the Colur Shift, which will effect the colur like Green to Yellow u can find the details on the below link.
http://developer.sonymobile.com/wp/2012/02/27/introducing-whitemagic-the-technology-in-xperia-p/
And u wont use full brightness in the Xperia P, so keep it auto and every thing will be Take over by Auto brightness sensor.
This issue will fixable or not?,
This issue is big for me,
I dont want to waist money...
So, What to do,
As per My Knowledge i hope there wont be any fix( Sony can Answer this)
If u Feel the Issue was Big, U can go for the other Mobile as u like
I dont know why are u taking this issue not serious...
Because, I know the Issue before buying the mobile, and i can ignore that.
Thanx for alert me...
Is this colour issue have on all xperia p device(all user)
Yes...Mandeep
So, why was u suggest this phone if this phone has screen problem which can not be fix...
For 26K i could buy brand new XPERIA S from ebay
For 20K you get XPERIA P on ebay. I bought mine from ebay.
