After use of Sony xperia Sola, i founded that Ram is too low,
I m decided to go with Sony Xperia P,
Actually, my phone budget cannot increase upto Rs.25,000/- Only(in indian Rupees) my phone requirements is
Dualcore cpu,
1gb Ram,
Atleast 4" display
good Gpu...
If Sony xperia P is not Good Option Then Please suggest me good Phone Please PLEASE PLEASE,
Thanx in Advance,
Good suggestion will mark as Correct Answer...
I bought mine with dealer warranty and saved 4K
Phone works all fine with no issues wrt display etc as noted on different threads. If it had gone bad the dealer wouold have replaced free with a new one.
Go for the Xperia P. or galaxy S2
Now I got Sony Xperia p from original Sony store,
I update gb to ics and I m facing from battery problem
Battery battery % droping in 1 min
I have charged 100% but only 2 hour battery backup in idle,
0% remaining, what is this,
Can u post the Screen Shot of Battery Graph.....
And After updating to ICS, Did u tried factory data reset with complete internal Storage ? if not do it , hope there will be some improvement.
The Android takes some time to settle Down so Dont worry, Do the factory reset, Every thing will be fine
Its normal, new battery gives its full power after 2-3 charge cycles. you will notice the effect only after 1-2 days.
Its also for the fact that battery claibration takes time and with usage pattern it gives correct estimate.
look for any hardware issues, battery will get normal after 1-2 days only !!
try this app :-
After 1-2 hours 50 dicreased...
there is also one more problem in ics that is nortification bar never stop..
ya, i update my phone with sony ericsson update service....
1-2 hours 50% decreased...
illuminum nortifiication bar not of...always on
Only of in lock
Monitor it for the next 2 days and if the problem is still there. you can go back to the sony store you bought it from. and ask for a replacement.
now i today charge again to 100%..
after switching of stand by mod...
1% decreasing after 30-40sec...
in 4 min 92% left without using...
Time to visit the retailer who sold you the device and ask for replacement if nothing else is there which could be causing this drain.
