Hi everyone,
I recentely upgraded my sony xperia u to android 4, and after three days the wifi began to not work properly. The icon keeps on showing that the wifi is connected, even if the network is not accessible, and I have to reboot the telephone in order to switch the wifi off/look for hotspots. Has anyone experienced the same problem? Any idea on how to fix it?
Thanks
Please run a repair to reload the firmware:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
5. Start.
6. Repair Phone
7. Continue
9. Next
11. Select Phone
This is a feneral issue for some Sony Xperia phone
http://talk.sonymobile.com/thread/61446?start=0&tstart=0
And Sony do not give any solution about it.
problem is, I already tried that and after three days the problem reappered. I really don't know what to do...
I've just found a solution to put off the wifi without restart the phone. Just download and install WiFi OnOff.
It does not solve the problem but it brings a little comfort.
If you have any other solution since last message please tell me.
Thank you.
update: I did it again and now it works properly. Thanks again!
