I have just had my xperia P up-to-date and there is a problem with the screen lock
harisflamingo
As you can see above, Im not able to change Swipe or other types. I dont know why. All I did is just update it normaly with the PC Companion Slightly_frowning_Face
Is there any one have the same problem Slightly_frowning_Face
please tell me how to fix it Slightly_frowning_Face
thanks a lot Slightly_smiling_Face
time to repair your phone with SUS
13 REPLIES 13
do you have a SIM pin lock? another screenlock app? any taskillers, antivirus, task managers, ram aps? what is that blue C icon top left?
harisflamingo
it's Advanced Mobile Care
and i also have Sreen Off FX. That's all
is it the reason of this problem?
(sorry for my bad english)
yes thats most likely the reason
tiniwings1
Hi,  check the settings under Settings->Security-> device adminstrators option.
if you see any application with check box enabled, then these application may be cause for the issue, they are forcing some security policies.
if you want to enable Swipe or other types just uncheck the applications in device adminstrators and confirm.
Reboot the mobile if necessary.
--TiniWings
harisflamingo
i tried but it did work Slightly_frowning_Face
you could repair your phone or do a settings reset
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
harisflamingo
that not actually what I want Slightly_frowning_Face
however, thank you anw Slightly_smiling_Face
have you uninstalled the apps?
jackxperiaP
try factory reset .. then install the firmware with SUS
