Hi my calendar widget always shows "no upcoming events" but when i go inside calendar app it shows all the events..And in my contacts i cant view my facebook contacts with their profile pictures(gmail contacts works properly)..
-new calendar widget from ics 4.0
-contact also from ics 4.0..
i have tried everything mentioned above but i still did not get an option to sync facebook contacts !!
go to settings > applications > storage use > facebook > clear data
now you have to log in with your id once again and when it asks to sync contacts , select sync all.
now surf the internet for some time , the contacts will get the pics.
my problem is not with synchronization of Facebook is with the synchronization of all events from my gmail account in the calendar widget
sorry i don't have any idea on this.
you can make a new thread for others to give you suggestions.
Calendar widget is still not showing the next event, after trying what you suggested. I think the calendar itself has the problem..
