problem in calendar widget and contacts
javith2dj
Hi my calendar widget always shows "no upcoming events" but when i go inside calendar app it shows all the events..And in my contacts i cant view my facebook contacts with their profile pictures(gmail contacts works properly)..
-new calendar widget from ics 4.0
-contact also from ics 4.0..
slimshaddy
Hero
have you tried to delete the calendar widget and add it again ?
after doing this restart your phone.
sometimes this happens.
go to settings > applications > storage use > facebook > clear data
now you have to log in with your id once again and when it asks to sync contacts , select sync all.
now surf the internet for some time , the contacts will get the pics.
14 REPLIES 14
slimshaddy
Hero
javith2dj
i have done as you said and its synchronizing..i will let you know the result after it gets fully syncd..
i started to experience this problem after the ics nordic update .the new calendar widget in nordic ics also didnt show any events but the old calendar widget showed it correctly and absence of profile pics in contacts was present in both nordic and indian ics
javith2dj
done ..it works..thank you so much man..
slimshaddy
Hero
great Slightly_smiling_Face
you'r welcome.
i am also facing the same issue with the Calendar Widget after the ICS update to my Xperia Arc S.
Most of my events are all days Events
After doing the thing mentioned by you i am still not able to see the event in the calendar Widgets any other pointers on the same.......
slimshaddy
Hero
so you deleted the widget but still this haoones ? did you try restarting the phone ?
Yeah I Sync the calendar again and then Deleted the Widget and add it again and then again Restarted  the phone as well but still it is showing no upcomming events....
Is there any way we can log a bug to Sony ...
in the mobile phone of my girlfriend I have the same problem, does not show the events in the calendar widget, any solution?
slimshaddy
Hero
did you try all the suggestions above ?
