Hi there,
After the recent ICS update on my new Neo V, the OS Android consumes more than 60% of the battery, I regularly clear the history and optimize by closing applications. I don't get even 12 hours of batterly life because of this. Can some one help me in fixing this problem. I am using GO launcher theme, not sure if this consumes more OS.
Thanks
Shiva
Hi
It is suggested to format your sd card and again reinstall your phone's software using-
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Hi
or
Hi Nabeel,
Great it indeed worked....... my phone battery back up is almost 36 hours with full usage......
Thanks
Shiva
