Hi all, I am Natesh Krishnan from India, I am using Xperia ION since May 2013. I was so happy with the SONY experience. Then after a long wait, got JB update from Sony. I have done the update successfully & i was so happy to have the new UI & mobile experience, and since 3 weeks, My phone is getting hanged whenever i Update my apps in google play, otherwise phone is working good. I tried several methods like Factory reset & still i am facing the same error. If u have any solution please share with me.
Thanks,
Natesh Krishnan
Hello nateshkv1989,
Can you please tell me which operator were you using previously and to which network have you changed to?
I m also having the same problem.I m from Bangladesh & I have tried each & every solution you mentioned so please sony fix this bug in ion JB update!!!
Hello Akshay,
I had this problem when I was in Sweden, using Lycamobile network.
Once i am back to India, i started using my Vodafone sim & It worked well..
Regards,
Natesh
Do you experience this both when you are connected to a Wi-Fi network and on your mobile data?
Does the phone behaves normally in other apps and features?
