original sony ericsson
how do we know that the neo v, i have buy is the original one?
you can use Update Service or PC Companion and see if it recognize your phone
7 REPLIES 7
Jake-SonyXperia
Agreed, this method will determine if the handset is a Sony Ericsson device.
i bought a mix walkman last week. i already connect my phone in my pc using media go, i created a playlist already..  it means i bought a really original SE phone?
thank you. hope for your reply.
Jake-SonyXperia
If PC Companion or media Go have been able to connect to the device then I believe that the handset will be a Sony orginal.
how to update android to ics 4.0?
im planning to buy next month the live with walkman.
does it is already an android 4.0?
im here in the philippines.
thank you.
To update you will need to use either PCC or SUS or Bridge for mac.
http://blogs.sonymobile.com/products/2012/03/30/the-vans-around-the-corner-android-4-0-ice-cream-san...
The first Xperia models to receive the upgrade will be Xperia arc S, Xperia neo V and Xperia ray. For these first models, the rollout will start mid-April and continue over 4-6 weeks.*
Following on, Xperia arc, Xperia PLAY, Xperia neo, Xperia mini, Xperia mini pro, Xperia pro, Xperia active and Sony Ericsson Live with Walkman will receive their scoop starting from the end of May/early June.*
srids
Oh....
PC companion and update service is stop recognizing my xperia neo after using for more than an year.
Earlier it was working and how there is no solution till today to detect my phone.
Does that mean my xperia neo is not original after one year Slightly_smiling_Face Slightly_smiling_Face
whall shall I do?? return it back to UK seller saying it is not original as sony pc companion and update service is not detecting now???
