NFC not working after JB update
ste71m
After JB update can't read smart tags
Here's my logcat
04-25 15:34:24.488: I/AtService(2315): OnBootBroadcastReceiver: Entering
04-25 15:34:24.488: I/AtService(2315): USER_PRESENT received
04-25 15:34:24.488: I/AtService(2315): OnBootBroadcastReceiver: Leaving
04-25 15:34:24.498: I/AtService(2315): onStartCommand: Entering intent=Intent { cmp=com.stericsson.atservice/.AtService (has extras) }, flags=0, startId=105
04-25 15:34:24.508: I/AtService(2315): onStartCommand: Leaving startId=105, result=2
04-25 15:34:24.508: I/AtService(2315): onStartCommand: Entering intent=Intent { cmp=com.stericsson.atservice/.AtService (has extras) }, flags=0, startId=106
04-25 15:34:24.508: I/AtService(2315): onStartCommand: Leaving startId=106, result=1
04-25 15:34:24.528: D/SizeAdaptiveLayout(2125): com.android.internal.widget.SizeAdaptiveLayout@419aa5c8child view android.widget.NotificationFrameLayout@419ac760 measured out of bounds at 94px clamped to 96px
04-25 15:34:24.688: W/NFC-LLC(2343): LLC length mis-match
24 REPLIES 24
xtraJosh
ok here is the step by step process i've done following instructions given by scarface.
1. clear data. i did not clear cache because there was none
2. uninstall updates.
3. disable smart connect. scarface said for 5 minutes, i think mine was more. i didn't notice the time because of work. lol
4. enable smart connect
5.i tried NFC with smart tags, did not detect. forgot to reset.
6. reset phone.
7. try again and this time it should detect the tags.
right after, it is then that i updated the app. cheers!
Scarface9
After updating.
You need to do  hard reset (hold down power button and both volume keys for several seconds and the phone will reset).
Let me know did it hel?
JonoXperiaP
Thanks
Same issue, removing smart tags and followign steps in fix above worked for me.
One note, when uninstalling updates to smart connect it asked to return to standard app so wasn't under downloaded apps anymore (under All) when finding to disable again.
bladesan
Tried the procedure Scarface9 mentioned, but still it does not work :S.
Cleared data, unistalled updates (under All apps), cleared data again, disabled SmartConnect, waited for 5min, enabled SmartConnect, updated and restartarted with vol up/down + power. No joy ..
But .. it does work when I remove my SIM card from the phone.
Then it can detect SmartTags and any other writeable tags I have.
I also tried Service Test -> NFC ... when SIM card is in the phone it does not detect anything. When I remove the SIM, it works.
BTW: I tried FactoryReset and Repair via Update Service.
PS: maybe it doesn't work, because I made micro SIM by myself (by cutting original SIM card) .. does microSIM have any other functionalities (somekind of ID that NCF-Wallet needs)?
bladesan
I can confirm, that after upgrading to .100 the NCF is working !! Slightly_smiling_Face yeah
