Hey buddies, I miss this forum so much
I just wanted to ask ; how can I open this type of file “Compiled HTML Help file (.chm)” in arc ???
The file looks like this in the attachment below .
Though there is an HTML viewer in arc but I don’t know why it doesn’t work ?!
Is there an app that could do the trick ?
And thank you very much .
http://www.mediafire.com/?mj2mnfminxi
or
http://www.mediafire.com/?0oghnra5hy2nu9z
download it and see if these are able to open your files..
download chm reader x
or
You're a genius . Thaaaaanks:smileycool:
lol thanx
i have a question..
i remeber you replying " why does the brightness uses 80% of battery "
what did you do to correct it ?? i mean some other user is facing the same problem so i suggested him to repair and turn off the bravia engine..
is this how you got your problem solved
Yes u r correct
Turning off Bravia ( whan not viewing videos etc..) would cut down on the display's battery usage to nearly "HALF"
hmm ok..lets see if it helps him or not
thanx..
Hey friends ,
I was wondering , is there any other app that also gives the ability to search for a word inside the chm file (which is a huge book)?
The app that slimshaddy told me about doesn't have this ability , and I need it so bad
Help !
http://www.brothersoft.com/downloads/convert-chm-to-pdf.html
see this..
do you have those chm files on your computer ??
i mean download any of the above softwares on your pc.
convert it to pdf..
search your words in your pc..
or transfer it back to phone and read as pdf
i think it has search option in it when you will read pdf files.try it..
note : just make 2 copies of your chm files in case the convertor corrupts it..
so better make a backup ok..
Hello everyone:smileyhappy:,
Need help again:smileyplain:
This time I'm having a problem with the original app "office suit":smileymischief:.
You see this app opens PDF files, but there happens to be a problem in viewing the images inside the PDF file; none of the images appear and the app says "this page contains objects that cannot be displayed". So could someone direct me to a different app that would preview the whole PDF file with all the pictures inside?
PS: The PDF file is not corrupted and it's viewable on the PC using "Foxit" or "PDF reader"programs.
And thank you very much.
