Hey,
About an hour ago my phone started acting weird. Everytime I tried to use the keyboard it closed whatever I was doign down (I was trying to send a text, but it closed down google and anything else I tried to experiment using the keyboard with).
So I tried turning it off and on again. Then I took the battery out for a couple of minutes (and put it back in)
I was just thinking about a system reset when it stopped turning on. I get a couple of flashing red lights sometimes. Occasionally it turns on, same keyboard problem, black screen within a minute.
I try and use the PC companion to update the software, but it connects, then tells me to pull the bar down from the top and click connect - there is no bar. It's just the charging screen. Turning the phone back on disconnects it.
Are there any other suggestions?
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
or
Neither of them work.
The phone connects, then it displays the charging screen with no status bar to drag down like the updaters ask, so I can't do anything.
Use SUS.... you don't need to drag any bar
You need to flash your phone and that's done when mobile is off
No need to even turn on your phone
Install SUS and follow the instructions
The SUS has been asking me to drag the status bar down
Could you please post a screenshot here so that i can understand on which step you are facing problem
Thanks
Although now my phone won't connect at all
What about drag bar screenshot ?
What error does it shows ?
It never showed an error. It just asked me to drag the status bar down and select connect. There was no status bar to do this, so I was stuck
My phone seems to be on again now, the time has been reset, but I still have all my numbers.
But the keyboard is still closing my messagaed down when I try and type. Sometimes it does straight to the camera from my conversations.
Also the Home button doesn't seem to be working
