My phone won't turn on
Hey,
About an hour ago my phone started acting weird. Everytime I tried to use the keyboard it closed whatever I was doign down (I was trying to send a text, but it closed down google and anything else I tried to experiment using the keyboard with).
So I tried turning it off and on again. Then I took the battery out for a couple of minutes (and put it back in)
I was just thinking about a system reset when it stopped turning on. I get a couple of flashing red lights sometimes. Occasionally it turns on, same keyboard problem, black screen within a minute.
I try and use the PC companion to update the software, but it connects, then tells me to pull the bar down from the top and click connect - there is no bar. It's just the charging screen. Turning the phone back on disconnects it.
Are there any other suggestions?
12 REPLIES 12
Nabeel
See, Switch off your mobile and repair your software...
If SUS asks you to drag status bar down, means that quite impossible... because SUS needs mobile to be completely switched off... i don't really know what program are you using
It could be a software glitch due to which your phone is working this way...
My sleeping time here, i wrote the steps above...
P.S. while using any of the programmes (SUS,PCC) connect your mobile only when you are asked to  and it should be switched off
Thank you for trying to help.
I realised that it was the PC companion that was popping up asking me to drag.
My phone doesn't connect to SUS at all.
Nabeel
Try using another PC...it should connect
Try turning firewall and antivirus, boot pc in safe mode with networking on
