I have an issue when I am updating my phone to .73.
I am up to the step where the PC Companion ask me to disconnect the phone and turn it off and connect with holding the down key, however, when I follow the instruction to reconnect the phone, it only have the green led on for a while and then turned off, goes into charge mode. So I am stuck in this step.
What should I do in order to proceed? What is the correct step I should preform?
Regards,
Hi, update phone with Update Service instead. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/.
Keep us updated.
Keep us updated.
Thanks alot!
This one works normally, an much easier process to update.
No problem ....
