Xperia neo v shutdown suddenly(2011 model , 6 months old)
Hi,My neo v is 6 months old , until now every thing was fine but suddenly it shutdown with out mt knowledge. when i tried to turn it on , nothing was happening. Later i removed battery and again inserted , it started that time . It happended twice in 2 days. May i know what is the problem ?
Nabeel
hi , i think you need to perform a software repair
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
both the links are same
6 REPLIES 6
Nabeel
                  or
I tried to update it , but it showed my mobile has latest software already Slightly_frowning_Face . No use
Nabeel
no matter it shows that,, select INSTALL ANYWAY
you need to reinstall your software.
do it
Aimee
Enthusiast
I'd suggest trying the repair option in PC Companion which Nabeelraza mentioned above. This will reinstall the software in your handset even if you're running the latest version.
Please also try running the handset with no third party apps installed after performing the repair and let us know how you get on Slightly_smiling_Face
What do you think about this forum? Let us know by doing this short survey
I did installed Slightly_smiling_Face my phone is very smooth now . will see , if problem won't occur again means i will be happy Slightly_smiling_Face
Nabeel
thats great
post in the news here again
Don't forget to mark the Correct Answers and Helpful Answers
