Try Velis auto brightness from the play store, it has a much better dynamic range than the Sony brightness handler. Depending on the curve used it can go from 0% at night to 100% in full daylight.
Dave
I've tried many times but it doesn't work for my SP.
don't know if this is a hardware problem or software.
I will try again and let you know.
hi..i have a problem about my brightness....every time i call, my brightness is ogg...my screen is black,so i cant use speaker,
keyboard (which is important ) ...and i have the last version .201 !!!! could u help me?????????
During a call it is designed that the screen goes off while the 'phone is against your ear (to reduce battery drain). Do you have some sort of case or screen protector that is obstructing the Proximity Sensor which is just left of the speaker mesh at the top of the 'phone?
Dave
ooooh...no my friend....ahm i must disable my stamina or something?
There is a test for the Proximity Sensor. In the dialler enter *#*#7378423#*#* that gets you to Service Test. Under this option, near the bottom of the list, is Proximity Sensor, once selected the sensor status should change from off to on when covering the top part of the screen.
Dave
