How to prevent accidental emergency calls from lock screen ?
jeronimo
I use Xperia SP Android 4.3.
When the phone is in my pocket, even if screen is locked, it makes accidental emergency calls...
I had the same problem with the camera widget from the lock screen, but I found an application that allows to disable it.
Is it possible to do the same for the emergency button ?
Thank you.
jeronimo
Thank you ils better now
3 REPLIES 3
Danial-mach1
Leader
I don't know if any app can do it but here two tips:
Turn off glove mode.. Dont put phone screen toward your body when you put it in your pocket
jeronimo
Danial-mach1
Leader
anytime
