Hi.
How to make a full format (hard reset) the smartphone?
If my system is not start, how to a hard reset? It's keys combination ?
please answer.
Regards.
BRICK ??
now thats a different thing
you could have asked this earlier
the answer is no, its not possible wothout pc and internet
use SUS on your PC
Update Service (SUS)
make sure that you have some charge on your battery, connect your phone to the wall charger if the LED doesn't turn on then there might be something wrong with either the micro USB cable or the Charger or the Battery
hard reset is not possible if I not have a computer and internet near smartphone???
{In my old phone (samsung omnia), I must the hold "green" and "red" and power on phone. Phone ask me "Do You format the phone?". After click Yes. System starting recovery from image...
After recovery is done, my system normally starting (blank system with all default settings and apps)}
try this , but don't know if it will work or not
hold POWER key and VOLUME UP key at the same time
5 seconds> restart phone
10 seconds> shutdown phone
You not understand me. Sorry my English.
I ask. How to a full format (hard reset) the system in phone if I not have a computer and internet ?
EXAMPLE:
this is a video presents hard reset omnia:
http://www.youtube.com/watch?v=94GdVqbjfWA
this is solution to omnia hard reset:
http://nokiaphonesolution.blogspot.com/2011/03/samsung-omnia-i900-hard-reset.html
How to make this on Sony Erricson Live With Walkman ???
did you try above suggesstion ?
press and hold both power key and voulme up key for 5 seconds. and see if your mobile turns on
if it turns on then good, then go to settings> privacy> factory data reset > ok
if nothing happens, unfortunately the option left is first post by uliwooly
there's a way to do a factory reset BUT your phone must work other than that you do need a computer and internet connection
How I make this, if my phone is not booting the system (android) ?
