Hi.
How to make a full format (hard reset) the smartphone?
If my system is not start, how to a hard reset? It's keys combination ?
please answer.
Regards.
does your phone has any charge left? turn off your phone, take the battery out, put it back on, press the power button does it turn on? does the LED flash RED? if it does flash RED then you need to charge the phone.
Try nabeelarza's suggestions but turn off the phone then press and hold the Volume Up and power at the same time, if that doesn't work try Volume Down if not then try both volume keys and power up, this is assuming that you have at least 50% of your battery
My phone is working normally. I want only ask.
If my phone (sytem android) accidentally brick (for example: on holidays), is possible hard reset (repair) without computer and internet.
Best regards.
Thanks.
I only want information, for the future
BEST REGARDS !!!
Go to settings -->> Privacy -->> Factory data reset. It will erase all data on your phone and if you wish you may also erase the contents on your SD Card.
how to get ride of a brick . i think my fone got bricked during ICS upgrade
repair it with SUS or flashtool
Update Service (SUS)
Unrelated topic, if you have some time please check this thread
plz help me …my wt19i is restarting again and again
it shows walkman logo only n then it jst restart ….so plz help me out
Me toooooo
