My ray's vibration has stopped working ,is there a bug or known problem about this situation ???what can i do ?
Hi, if it didn't work in the service test, I guess you need to send it to Service Centre for repair.
Anyway, no harm repairing the software as suggested by Nabeel.
Hi, since when it stopped working ?
Dial *#*#7378423#*#* in dialer > service test > vibration > press menu button
see if your mobile vibrates there
TNX for your reply
nope I already tried the service test but there is no vibrates there
Is it possible that it has broken because the ray has vibrated too much ?(the early mornings and snoozes you know :smileywink:)
Lol maybe
last thing to try before service center
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
ok I'll check it out
I already hinted him about the service center
check my second line below
Yup, I know ....
It didn't work,anyway I guess that the nearest sony station is the best solution for me now (although I never dropped my phore or anything like that)so BB
