HELP !! ray's vibration has stopped working
My ray's vibration has stopped working ,is there a bug or known problem about this situation ???what can i do ?
gwhispererz
Hi, if it didn't work in the service test, I guess you need to send it to Service Centre for repair.
Anyway, no harm repairing the software as suggested by Nabeel.
8 REPLIES 8
Nabeel
Hi, since when it stopped working ?
Dial *#*#7378423#*#* in dialer > service test > vibration > press menu button
see if your mobile vibrates there Slightly_smiling_Face
TNX for your reply
nope I already tried the service test but there is no vibrates there
Is it possible that it has broken because the ray has vibrated too much ?(the early mornings and snoozes you know :smileywink:)
Nabeel
Lol Smiling_Face_with_open_mouth_&_closed_Eyes Dizzy_Face maybe
last thing to try before service center
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
gwhispererz
ok I'll check it out
Nabeel
I already hinted him about the  service center Winking_Face
check my second line below Winking_Face Winking_Face Slightly_smiling_Face
gwhispererz
Yup, I know ....
It didn't work,anyway I guess that the nearest sony station is the best solution for me now (although I never dropped my phore or anything like that)so BB
