Xperia does not start anymore after a while
It seems that the Xperia goes into some "deep sleep" after a while of non-usage. Typically an hour or so. The only way to start the thing up is to remove the battery??? We have installed latest updates, switched SIM cards, but no result. The phone is completely useless. It is a shame.
Nabeel
Hi, see if it helps Slightly_smiling_Face
Backup everything on phone memory as the process would erase all
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
Nabeel
                  or
