I can't take the backup of my contact in memory card.
I know how to take the backup. When i done the backup it says"unknown error".
Please help me.
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
You need to format your sd card
Backup important stuff from memory card to pc and format your sd card ( settings > storage > erase sd card )
i have tried this
or
ok, but if i repair the software, then can it remove all the data in phone?
Yess it will remove all data in phone memory
My advice is to format your sd card again and then reinstall phone's software.... you mobile may become fast and your experience may change a lot
but, if i update the software i will loss all my contact and messages which are story in phone.
and i have no backup for this.
Backup to sim card
Do you have another memory card ? it would help to test as well
Even sync your contacts to gmail.... settings > account and sync > turn on > add account > gmail > mark all
in my sim card i only store 250 contacts, and i have tried in another memory card, but same problem.
see if it works
https://play.google.com/store/apps/details?id=no.uia.android.backupcontacts&feature=search_result
backup contacts to sd card and send the saved file to computer as well
format sd card and repair
